Throttle Play
Old Jan 24, 2006 | 10:00 PM
fullmetalf4i's Avatar
Default Throttle Play
Ive notived that on my F4i I've got about a 1/4 turn of throttle play. is this normal? I've been attempting to be more percise with my throttle control. Going into corners, especially on a race track throttle should be crack at the entry and opened at an even rate through the rest of the turn. anything i can do to get rid of this free play?
Old Jan 24, 2006 | 10:02 PM
randall's Avatar
Default RE: Throttle Play
have the same free play. Thought mine was normal being i have close to 18,xxx miles
Old Jan 24, 2006 | 10:42 PM
fishfryer527's Avatar
My 06 has about a tenth of a turn, but is very abrupt right opening and closing. It makes certain slow speed turns annoying. At the 600 mile checkup they said it is normal. My buddies 1000RR has a much smoother throttle.
Old Jan 24, 2006 | 11:04 PM
doncollins's Avatar
Retired Administrator
Yes.. you can adjust the throttle. You'll see a nut and sleeve near your bend where it connects to your throttle. Loosen the nut and make the adjustment. If that's not enough... the major adjustment is on the other end where the cable connects to the carbs/throttle bodies. That's the tough one to get to because you have to remove a lot of plastic.
Shawn05F4i
Sep 5, 2009 07:55 PM
G-ShocK
Aug 26, 2009 04:19 PM
travisb
Nov 28, 2007 03:37 PM
CBRYDR
Sep 20, 2007 09:20 AM
britman
Sep 18, 2006 09:54 AM
