Think Ill Run To Lean? Help Me Out
okay guys and gals mods are as follows
k&n air filter, intake resonators deleted, f4i air box mod, power commander PCIII, straight pipes....
do you guys think i could be running to lean? How reliable is the rich/lean gauge on the display of the pcIII?
the part im debating right now is the straight pipes... i plan on doing a undertail routing... not coming straight off the header since our pipes is 2.25 ide run a single 2.25 undertail and split to a dual 1.5 inch outlets... do u think this would lean out my bike or not... any suggestions?
I realize people are prolly going to say dont run straight pipes they are too loud.... for my custom build im just trying to get the pipe routing down first... i will possibly later be building and adding my own mufflers but for now i just need something to start working with...
if anyone could help ide greatly appreciate it....
thanks
thanks
well the only thing that might make it lean is the straight pipe. if you ever look at your maps for the PC3 they pull so much fuel in the mid range i dont see you going lean till the top end maybe. dyno jet told me that a K&N is the same as a stock filter so that will not change anything at all.
