Are these ebay pegs any good?
Anybody use any like this? They look nice. I have stock pegs. Would they be comfortable? What's the difference between good pegs and china-pegs?
Black Honda Front Rear Set Foot Pegs Footpegs CBR600 CBR 600 F4i F4 F3 F2 F1 | eBay http://i.ebayimg.com/00/s/ODAwWDgwMA...Gog~~60_57.JPG Toktogi is on |
I used a set of those on my Buell when I had it.
I had to drill them out to make the factory hardware fit, but after that, they worked great. I would imagine you won't have that issue as those are specifically for your Honda. I had to use a set that were for a different brand of bike. But as far as how they worked, they worked fine after I had them fitted. |
Cool, I might order them. How easy is it to swap them out?
Toktogi is on |
Originally Posted by theadamie
(Post 1275995)
Toktogi is on Very easy. Peg is held on by a big pin with a split pin through it. Take note of the location of the spring so you can put it back the same way, remove split pin and remove pin, voila. Install is the reverse, although you may as well clean any crud out and replace the split pin whilst you are in there. I'd also loctite the thread between the silver and black parts too, to stop them unscrewing. |
Go with the adjustable ones
