Temperature
Old 03-19-2007 | 04:41 AM
themadpaki's Avatar
Default RE: Temperature
yea, same 180-220, it only goes past 220 when i'm on that throttle for a while.
Old 03-19-2007 | 10:17 PM
02f4iSailor's Avatar
my bike runs like 236-239 in the city.
Old 03-19-2007 | 10:29 PM
alekinci's Avatar
ORIGINAL: ddaren
i run 92... my bikes goes up to 240 a lot during sunny days in traffic. something wrong with my bike or is this natural?
i would suggest you start using like 89 or 87. 240 is a lot. i have never went over 227. a mechanic told me once when i was low on coolant to fill it up and to keep in mind that if i go into 245 i should pull over and let the bike cool because i can cause serious damage. not sure if thats true, but i would say that you are running hot. you might have more anti-freeze than water in your tank, i would drop some "water wetter".
Old 03-19-2007 | 10:48 PM
mattyrides07's Avatar
I live in Las Vegas, NV. My bike runs at 180 on the highway. However, when I commute on it in the city (4-5 times a week) it'll reach 225 and that is when my fan turns on. If you're stopped at a stoplight and your temp gets into the 230s: Turn off the ignition, then turn the key back to the "on" position so the fan will continue working with the engine off. When that signal light turns green-turn the bike back on.This is a fail proof way to keep your bike cooler in the warmer weather.
Also, I heard about adding an extra blade to the fan??? I'm going to try it later this summer to see if it makes a difference.
Old 03-20-2007 | 01:26 AM
ChanCBR's Avatar
^^ good idea
Old 03-20-2007 | 01:51 AM
alekinci's Avatar
^^ not the best idea... you can just press the kill switch and let the fans always be on until you reach 224. after the fans stop then just press ignition.... its not the best thing to turn off your ignition/lights at night on a red light.
try the water wetter
Old 03-20-2007 | 05:07 PM
Engdahl's Avatar
i thought that i read in a manual maybe the service or owners that if you see 235 you should pull over...
One of my spring projects is to wire in a button so that i can turn the fan on at long lights so the bike doesnt get very hot...havent decided if i am going to use a toggle or borrow the horn button for this....
Old 03-20-2007 | 06:36 PM
ninetyfivehp's Avatar
the fanturns on my 06' at 217-220 and the temp has never gotten over 225 even in summer stop and go traffic
Old 03-20-2007 | 07:02 PM
slip_'s Avatar
Same here, haven't seen anything above 225.
Old 03-20-2007 | 10:28 PM
ORIGINAL: alekinci
Well, turning the switch off to on takes me like 0.05 seconds. I don't know how slow you are...
Quick Reply: Temperature
