Tacómetro.
Old Mar 8, 2024 | 11:09 PM
fuentessegura's Avatar
Default Tacómetro.
Hi, My tachometer doesn't work. The initial check does it but then the marker stays at 0. I have tested the instrument panel on another motorcycle and it works correctly. The fuses are all good and I have checked the wiring and apparently there are no shorts.
I have checked the yellow/green cable of the control unit and it shows the voltage indicated in the workshop manual, so I suspect that it works correctly.
Something similar has happened to some of you. thank you
Jeff Hendrickson
Apr 29, 2019 11:23 PM
ThisGuy'sTattedUp
F2 Tech
May 14, 2012 11:33 AM
Matt40567
F2 Tech
Jun 7, 2011 05:21 PM
rick420
Jan 24, 2009 11:12 AM
delta
Jul 8, 2006 01:08 PM
