-   F4i - Main Forum (https://cbrforum.com/forum/f4i-main-forum-11/)
-   -   Stripped spark plug hole (https://cbrforum.com/forum/f4i-main-forum-11/stripped-spark-plug-hole-129842/)
ajreyno1994 Aug 19, 2011 04:23 PM
Well guys, went to change my plugs today and can't get #3 to tighten, my dad is working on it as we speak. If it won't tighten though, what are my options? Please help
MadHattr059 Aug 19, 2011 04:54 PM
Heli-coil. That's what they're made to do. Go to your local auto store
and ask for a heli-coil kit. It's basically like a spring that winds into your
hole after your do a small ream on it.
HeliCoil Corporation
Good luck on that, Ern
aurora_F4i Aug 19, 2011 05:59 PM
Get a grade 8 bolt, the goldish one and get it lined up and try to re tap it. It will clean it up. It's much harder than the engine block.
ajreyno1994 Aug 19, 2011 06:11 PM
So I'm not totally screwed?
gotcbr Aug 19, 2011 06:37 PM
MadHattr059's advice is spot-on.
aurora_F4i Aug 19, 2011 06:50 PM
Not at all, the helio coil will work, just if you have a grade 8 bolt laying around it might do the trick.
ajreyno1994 Aug 19, 2011 07:09 PM
I don't have either. What all would the coil consist of me doing
Soulhammer Aug 19, 2011 09:17 PM
Heli-Coil is very simple to use, it comes with its own tap/reamer and crank, all you do is turn it in usually you go 1 turn forward half turn backwards and repeat, then theres a heli-coil install tool which threads it in and it threads off but the coil stays in place, its the best solution to stripping you can do
boredandstroked Aug 20, 2011 10:59 AM
Nobody is mentioning that if you do this with the head on the block then you get metal shavings in the cylinder.
ThaBrock Aug 20, 2011 11:17 AM
Get the piston at the top position and pick out the large pieces with a oily object (screw driver?) and the smaller pieces should blow right out the tail pipe?
