strange prob with brakes
I have an 01 F4i and since a couple of months I have this problem with my brakes. When I start the bike and get going, the brake lever is soft and i can almostly squeeze it all the way before i achieve a good braking effect. After plunging the lever a couple of times , the lever gets to its normal self (it gets hard and i can achieve maximal braking with just minor pressure with my finger) As soon as i spend a minute or so not using the brakes, the lever becomes soft again. I did bleed my brakes but the problem remained there. Do you think that upgraing to the SS lines will solve the problem?
Thanks
Chris
Thanks
Chris
RE: strange prob with brakes
Check your seals around the calipers behind the pads as well. Look for residue on pads . Find this problem in a hurry before you need to quick brake and plant your face on the side of some assbags car that pulled out in front of you. This ones about as serious as it gets.
i hear you raft!
we will soon be going overland for a 2 week trip with the bikes and i really want to sort it out now. The brakes never failed me actually... I can always get as much braking as i need, even emergency braking. However i got really fed up to find a stiff lever and a second later the lever is soft like a baby's ****
thanks for the quick reply guys!!
so u think it is the master cylinder ey? I will have a look at the manual to see what a rebuild involves. I will try and rebleed them again and if that doesnt work i will rebuild the MC. If still no luck, SS lines would be the last think to replace (apart from the calipers)
Thanks guys
Thanks guys
