Stock Clutch Kit?
Stock Clutch Kit?
Hey all. I bought an 01 F4i recently and I'm in the middle of giving it some TLC in order to get it where I want it. So, one of the things on my list is a new clutch kit due to the current one slipping slightly. After doing some reading there seems to be a general consensus that the OEM kit is the best way to go. I don't really want to go through a dealer because they always seem to have the guaranteed highest price on everything. SO, can anyone throw me a link for somewhere I can order a stock clutch kit? Or are there any other suggestions on what I should get? Maybe something near the same quality? Any and all help is appreciated! Thanks!
On bikebandit.com under F4i OEM clutch parts there is a long list. I think I read that all the discs are the same except for the outer two? So what out of this list will I need (including how many of each)? I'm also wanting to replace the springs since they are relatively cheap. How many of those do i need? Again, thanks for any help and sorry for the newbish questions.
1:
SPROCKET (25T)
(25T),A AC
$39.40 2:
CLUTCH (OUTER)
$192.93 3:
GUIDE, CLUTCH
(OUTER)
$14.13 4:
CENTER, CLUTCH
,AC 2AC
$71.58 5:
SEAT, JUDDER SPRING
,AC 2AC
$7.60 6:
DISK, CL FRICTION
,AC 2AC
$11.40 7:
DISK, CL FRICTION
,AC 2AC
$9.25 8:
DISK B, CL FRICTION
,AC 2AC
$11.40 9:
PLATE, CLUTCH
,AC 2AC
$11.09 10:
PLATE, CLU PRESS
,AC 2AC
$42.58 11:
SPRING, CLUTCH
$3.27 12:
SPRING, JUDDER
,AC 2AC
$14.95 13:
PIN, CLUTCH LIFTER
$14.31 14:
BOLT-WASHER (6X28)
(6X28),A AC
$2.73 15:
NUT, LOCK (22MM)
(22MM),AC 2AC
$7.42 16:
WASHER (22MM)
(22MM),AC 2AC
$6.16 17:
WASHER (60X25X3)
(60X25X3)
$4.62 18:
BEARING (16003)
(16003),A AC
$16.16 19:
BEARING (35X42X23)
(35X42X23),A AC
$60.29
1:
SPROCKET (25T)
(25T),A AC
$39.40 2:
CLUTCH (OUTER)
$192.93 3:
GUIDE, CLUTCH
(OUTER)
$14.13 4:
CENTER, CLUTCH
,AC 2AC
$71.58 5:
SEAT, JUDDER SPRING
,AC 2AC
$7.60 6:
DISK, CL FRICTION
,AC 2AC
$11.40 7:
DISK, CL FRICTION
,AC 2AC
$9.25 8:
DISK B, CL FRICTION
,AC 2AC
$11.40 9:
PLATE, CLUTCH
,AC 2AC
$11.09 10:
PLATE, CLU PRESS
,AC 2AC
$42.58 11:
SPRING, CLUTCH
$3.27 12:
SPRING, JUDDER
,AC 2AC
$14.95 13:
PIN, CLUTCH LIFTER
$14.31 14:
BOLT-WASHER (6X28)
(6X28),A AC
$2.73 15:
NUT, LOCK (22MM)
(22MM),AC 2AC
$7.42 16:
WASHER (22MM)
(22MM),AC 2AC
$6.16 17:
WASHER (60X25X3)
(60X25X3)
$4.62 18:
BEARING (16003)
(16003),A AC
$16.16 19:
BEARING (35X42X23)
(35X42X23),A AC
$60.29
HydroPrelude85
F4i - For-Sale / Trade
04-07-2012 07:44 PM
