Steering Stem
Old Sep 17, 2008 | 11:12 AM
some guy #2's Avatar
Default Steering Stem
How big is the nut that is at the top of the triple tree? Is that the easiest way to tighten the steering stem?
Old Sep 18, 2008 | 12:58 AM
02cbrf4i4u's Avatar
Default RE: Steering Stem
I bet you could find out this info in the F4i Manual.
Old Sep 18, 2008 | 08:49 AM
No luck, only torque spec. Unless I am blind. I'll just measure it and hope fo the best
Old Sep 18, 2008 | 12:30 PM
Jaybird180's Avatar
I have the tool at home. I'll see if I can get the size for you. There's a post where I asked the same Q recently. If you get the search to work, find it under one of my posts.
Old Sep 18, 2008 | 02:51 PM
I just want to tighten the bolt to see if that will eliminate the clunk noise when I brake. Not going to do anything major since I don't have the materials.
Old Sep 18, 2008 | 03:41 PM
Tahoe SC's Avatar
it's not just that bolt. once you remove it you'll see that there's another bolt that you need a "special" tool to remove or turn. i think a spanner wrench should work on that though. as far as the klunking, it may be time to change the head bearings.
Old Sep 18, 2008 | 03:58 PM
I read that and other sites suggested tightening all the bolts on the clamps and stem first.
Old Sep 18, 2008 | 04:00 PM
Okay, n00b question, what is a spanner wrench?
Old Sep 18, 2008 | 05:47 PM
Jaybird180's Avatar
A spanner is British for wrench. The head nut is 30mm.
Old Sep 18, 2008 | 06:55 PM
Thanks a bunch. That's what I thought a spanner wrench was but google said otherwise.
