steering is shaky, do i need a damper?
RE: steering is shaky, do i need a damper?
To check play in the steering, put the front tire between your legs tightly. grab bars and try to move them without the tire moving, you shouldn't be able too. One way to check your frame is too strip all body work and look close at all fasteners see if any have moved.If they have it won't be very much but it means something got bent.
it was sitting on the tires for the winter...but i kept moving it quite often...so i dont think thats the problem
and i didnt think of checking the tire w/ it between my legs...ive been mountain biking since i could walk, so i know that trick!
from what ive heard...it doesnt seem like the frame could be the problem...its a vibrating, no so much a misalignment problem
i just wish there wasnt 6" of snow on the ground...so i could go out and test everything out
ORIGINAL: Leveltwo
f4is have vibrations in the handlebars normally, is it a vibration, or can you see the handlebars shaking?
[sm=boohoo.gif][sm=headbang.gif]
If it's vibrations (and they get more intense the faster you go).....usually it's a unbalanced (or flat spotted) tire. That's pretty cheap to check and rule out, so I would take it to a shop and have them rebalance your tires and check them over. If it stops......horay! If it continues, you know it's not the tires or wheels. (and have them do both front and back).
Also, if it's misaligned, usually the bike will pull slightly to either side. So I would check to see if it pulls to one side or the other.
Other than that, no clue.
I have the same problem intermitantly, it depends on the type of road I'm on, the rougher the worse it gets. From doin wheelies someone told me my front wheel bearings were egged out do to hard landings. Do u stunt at all or hit a large hole when you went down.?
