stater cover broke =(
Need help, recently laid down on left side on dirt area. stater cover cracked and not sure if any dirt got inside but I am sure it did. Is this as simple as it seems? just remove broken stater cover, clean inside and replace? I have not actually taken off anything as of yet, just trying to get an idea of how difficult (if it is) this will be. Will start working on the bike this weekend, need any help. thank you
cool. actually all the oil leaked out already when i laid down. =/ hopefully this is a simple fix. everything (not including fairings) seem fine. Thanks!
I used gasket sealer and applied some to both sides of the gasket, and it stayed in place. This made it a little easier. I also used some RTV silicone, for the stator wire.
Make sure if you use some if this stuff, that you are in a will ventilated area, because these products are very aromatically strong.
where can i purchase this gasket? the dealership most likely right? do i have to use an oem one?
04_CBR
03-09-2009 10:18 PM
