starting problem
Old Jun 27, 2013 | 09:36 PM
dgk600f4i's Avatar
Default starting problem
When i go to start my bike it cranks for id say about 30 sec maybe longer before it fires. When the bike is warm it still cranks longer than usual but not as long as when its cold. Any ideas? I changed the plugs begining of the season. Thanks
Old Jun 28, 2013 | 08:51 PM
omg209's Avatar
when was the last time the battery was changed?
Old Jun 28, 2013 | 11:54 PM
svek's Avatar
So you have to hold the starter button down for 30 seconds before it fires? I'm surprised your battery can sustain that... Anyway, I've heard of a fuel pressure regulator causing long cranks like that
Old Jun 29, 2013 | 01:54 AM
dman007's Avatar
Registered Users
A constant 30 second crank can't be good on the starter motor either.
Have you check gas lines for kinks or misrouting.
Definitely sound gas related. Not sure any other engine component would cause such as issue.
Old Jul 16, 2013 | 09:12 PM
dgk600f4i's Avatar
Checked the fpr and its fine but the battery starts to.die out and il let.off and hit it again and it fires quick
Old Jul 16, 2013 | 10:55 PM
svek's Avatar
I agree it sounds fuel related, do you have a copy of the service manual? If not, search on the forums here.
This is a screen shot of the manual. Things you need to look at to figure out your problem:
dirtyhall
Apr 15, 2011 08:41 AM
CBRPutty
Aug 12, 2010 09:04 PM
dgraviett
Jul 14, 2009 10:59 AM
whtan20
Nov 25, 2007 01:36 AM
ITZOBIG
Apr 14, 2007 11:56 AM
