Start up deteriorating
Over the last couple of weeks the startup on my CBR 600 F-Sport (F4i?) has deteriorated. It has always typically started instantly. However one day it took an extra half second, and gradually slightly longer each time. Today it must've been at least 3 seconds, to the point where I'd be worried it wasn't going to start, or would flood or something bad. Adding gas seemed to make no difference. It still starts instantly if I've been out and about on it.
Is there anything obvious I can start to check?
Other info:
The battery is approx 1 year old and always kept on optimate if I'm not using it for more than a few days. Optimate still seems to show it's holding charge ok.
No warnings lights anywhere on dash.
Only aftermarket part is the exhaust, which has been on there for years.
Can't think of any other info that would help.
Any advice appreciated.
Thanks.
Other info:
Thanks.
Probly a rip in some rubber part that gets gradually bigger -> possible vacuum or intake leak. Have the engine on idle and spray short bursts of motor starter spray around the intake manifold. If your revs peak you got an intake leak. Just don't empty the whole can in there as it will eat rubber if let sit on it, a few short bursts is enough.
Go through your vacuum hoses for rips or tears. And while you're down there inspect the plugs. Might be a valve clearance issue although I heavily doubt it.
Its your battery. Took me years and almost 70k miles to figure it out too. Since my bike was about 6 months old I'd have a random hard start. It would crank and crank but only start if I opened the throttle. Also only happened after bike was hot, and was very random. Since it always cranked, I never thought battery. But it is.
JayBoCC2
06-23-2009 10:23 PM
