sputtering when i first start it up
When i first fire up my bike it seems to sputter a little bit and idle slightly lower than it used to. It clears up after a quick minute or if I give it some gas and it rides and runs great otherwise.
Is there anything i could check? It's doesn't seem to be a problem, but it's only been doing it for a few days so i thought it was strange. I bought the bike in May with 2800 miles and it has 6800 now. Thoughts?
________
Ford parklane
________
Ford parklane
RE: sputtering when i first start it up
I don't mean to jinx it, but my battery died shortly after my bike did the low idle thing (1100 rpm cold, not 1500 which was normal). I don't remember the sputtering but maybe that happened too. My battery only lasted 6500 miles so, check that first. Let us know.
There is a idle adjustment. I have never needed to adjust, but it's just forward and above the shifter lever. Black plastic ***.
Hope it's not your battery I just droped in a new one because the other was old and I spent 100 for a westco. not cheap.
Age means more than miles on a battery. infact a bike ridden alot will have a battery that last longer. If it's original I'd call it trash anyways. 5 years is a good run.
ORIGINAL: rodantking
Idont know if its the original battery or not. Could be since i bought it 5 years old with only 2800 miles.
Seems strange that a battery would cause this.I would think the stator/generator/ whatever you call it would put out enough juice to make the bike run right.
My bike always ran perfectly smooth immediately after i started it. Maybe this is normal. I guess i'll keep riding and see if it gets worse?
________
AMATEUR VIDEO
________
AMATEUR VIDEO
ORIGINAL: fishfryer527
ORIGINAL: sofakingtore420
i idle at 900-1000 once warmed up , when cold it idles at 2000-2500
New battery ordered from motoxoutlet.com for just over $51 shipped. Thats sealed and acid in and charged from the factory by the way.
