split seat to banana seat
I know banana seat to split seat has been done to death but what parts do i need to swap split seat to banana seat.
I do have the banana seat rear frame though I bought that the other day off ebay but can i use the split seat frame bolts to bolt the banana seat frame on or are there additional bolts. Also is the wiring harness different or is it the same just routed differently? thanks |
Welcome to the forum, not sure if anyone has done this way round. We shall see if anyone comments.
Other than that Your best bet is to compare the scematics below to see if there are any difference in part numbers. The Harnesses look the same, but do have different codes for the last three letters 32106-MBW - A10 v A40 You will need the fender and cowl for definite. Split Seat Frame https://www.ronayers.com/oemparts/a/...6b/frame-99-03 Rear Fender https://www.ronayers.com/oemparts/a/...r-fender-01-03 Rear Cowl https://www.ronayers.com/oemparts/a/...ear-cowl-01-03 Loom https://www.ronayers.com/oemparts/a/...-harness-01-03 Banana Seat Frame https://www.ronayers.com/oemparts/a/...55/frame-04-06 Rear Fender https://www.ronayers.com/oemparts/a/...er-99-00-04-06 Rear Cowl https://www.ronayers.com/oemparts/a/...ear-cowl-04-06 Wiring loom https://www.ronayers.com/oemparts/a/...-harness-04-06 |
Originally Posted by Al1040
(Post 1357274)
Originally Posted by mc_hawkings24
(Post 1357280)
Thats a great help thank you for the links i can compare parts now. I know its not something people do by reverse engineering to a banana
where are you based? If you’re local we could look at exchanging parts? I have the banana seat version F4. regards, adam |
| All times are GMT -5. The time now is 03:14 AM. |
