Speedometer problems
So I've been searching this forum and it seems that no one has the problem I have on my speedometer. Well anyways, my problem on my speedometer is that the RPM meter wont move and the time is never stored even after setting it. Everything else works fine. Anyone have any ideas on what it could be?
Originally Posted by highercal
(Post 1019928)
If so maybe you have a loose connection in your gauge or a loose wire in a connector for your gauge. |
Originally Posted by jeffjones
(Post 1019945)
Have you taken your gauge apart before it happened or dropped your bike?
If so maybe you have a loose connection in your gauge or a loose wire in a connector for your gauge. Ill re-check the the connection for it. |
(Post 1019948)
It was dropped before but the gauges and all worked fine up until last night. I noticed it when starting her up after a week of sitting in my garage.
Ill re-check the the connection for it. so I checked all the connections and fuses and everything seems fine. I fixed my clock issue but the RPM wont move at all. My MPH displays just fine the only that not workin is the RPM. Any ideas?:icon_shrug: |
did you check the internal connections?? if you pull the gauges off the bike...including the wire harness, there are two internal connections hidden behind rubber grommet. sounds like one came undone.
Originally Posted by Xander F4i
(Post 1020207)
(Post 1020210)
The internal connection that are covered with a plastic covering with 2 screws? How do I detach those wires? I'm thinking one probably corroded or something.
(Post 1020221)
You have to take all the little screws out and take the black plastic cover off exposing the circuit board.
Wires look good, I noticed that when I put the key in and put it on, the RPM meter goes up and down. Could it be my speed sensor going bad? |
yes im having the same issue , i hope we find the correct answer , also i know on the f3's when you change the gearing it throws the speedometer off is it also like that on the f4i?
Originally Posted by 99f4i
(Post 1020334)
If anyone has a fix or help on this please contribute!! Thanks! :icon_urinal: |
