Sounds strange
Well, if you remove the saddle and look at the left side of the bike, you will gind a small plug that is not connected to anything. If you take a piece of wire and connect both ends in the plug, and then turn the key to On position, the FI light above your tachometer ( the one that normally turns on for a couple seconds when you switch the bike on) will start blinking, if there is something wrong.
I can get some photos if you want.
Spark plugs:
4 x NGK Spark Plugs HONDA CBR600 F4i 01-06 NGK PN# IMR9A9H | eBay
Spark plugs:
The bike starts correctly, except that day. Now its stoped since 6 days. Tonight i will try to run and if it not start correctly, i will change before maintenance
Somebody can tell me some shop to buy the Spark Plugs online, or where you usually buy the Spark Plugs. Here in Spain cost 200 Dollars in Honda Oficial Shop
Do you have a Spanish eBay?
Also try looking for DENSO IUH27D, might be cheaper.
Spark plugs:
Spark plugs:
Thank You
I have fear that the spark plugs iŽll buy, can be of bad quality and break the motor
