So0o0o0o......
So0o0o0o......
I got bored today and decided I would cut down my exhaust and make it a nice little shorty. I cut the can down to size, took out the packing and baffling, then i went to remove the rivets from the end i cut off so i could put everything back together. I bought a pack of brand new drill bits, put one in the dremel and it burnt the bit right up. I tried using a regular drill with a new bit and again the drill bit just got burnt up. I went through about 4 bits and they did NOTHING to the rivet. I tried to punch the rivet out with a nail set...nothing. I tried to grind the head off the rivet and that still didnt help. I dont know what the f*ck these rivets are made of or if im doing something wrong buuuut ill take any suggestions. In total i went through 4 drill bits, 2 cutting wheel discs, and a couple random other dremel bits i used when nothing else was working. (and yes they were high speed steel titanium nitride coated drill bits)
yeah im just using a dremel to grind them since thats all i have but i gave up once i started burning through drill bits and cutting wheels. I tried using a stone wheel and some other stuff too but those did nothing. I guess ill just keep grinding away at them with the wheels and hopefully ill be able to punch them through. I even tried using a half inch drill bit just to drll through the head of the rivet i dunno why these things are such a pain but whatever...im sure ill get em out eventually.
its a jardine. haha yeah me and my friend were just staring at each other like "whaaaaaat the hell are these rivets made out of?" weve cut/drilled through all sorts of stuff but these rivets were just chewing up drill bits and stuff like they were made of tin foil. I decided to cut slits in the can so the rivets could slide out and just hammered the end off with a mallet then cut the rivets from there.
Heres a quick picture i took of the final product. I didnt put any of the packing back in, just the baffle. Im gonna ride around and see if its too loud/obnoxious for my liking and if it is ill pop the end off and stick some packing in there before i rivet it back together. It sounds and looks 1000 times better than before though but I only turned the bike on inside the garage. Tomorrow if its nice ill take it out and get some better pics of the whole bike and see how it really sounds as well.
