Snatchy Throttle
I have 2002 F4I low milage bike it starts up fine, ticks over fine and revs fine. Never misses a beat.
However I find the bike rubbish around town, slow driving. I find the throttle very snatchy. Going around a traffic Island or a corner can be a nightmare with the on off gas reaction I get. I am a very experienced rider been riding longer then I care to remember so I dont lug engines. Last service was about 1500 miles back which included new Iridiam plugs. The old plugs by the way showed me no probs with how the engine was running. My question is would a power commander cure this problem ! I really dont want to lay out 300 plus for something that wont cure it. However if it will smooth it out I will do it. Does anyone else have the same problem as me ? And if so and you fitted a PC did it really make a difference ? Cheers Jak... |
Have you adjusted the freeplay on the throttle, it makes a big difference.
Hi Rob2m
Throttle free play is good. That was the first thing I checked. |
Have you given the injectors a look? Fuel filter? Fuel pump? Anytime hesitation or jerkiness is involved I start with the fuel delivery system.
Could also be a dead spot in the TPS.
Originally Posted by Rybo
(Post 1308206)
Its just when I slow right down for a tight turn when i start to give it some gas again that the problem happens. It feels like its me being snatchy with the gas except its not. Had the same sort of problem with Yamaha xt models. Wel known. Very nervous, the only thing that ever cured them was a PC. |
Originally Posted by 74demon
(Post 1308207)
Throttle position sensor.
If it has a dead spot around the fully closed position, the first reading it gives the ECU is at an open position. It's pretty easy to test with an ohmmeter as it is just a variable resistor that changes resistance with throttle position. |
(Post 1308237)
If it has a dead spot around the fully closed position, the first reading it gives the ECU is at an open position. It's pretty easy to test with an ohmmeter as it is just a variable resistor that changes resistance with throttle position. Have also found I have a very tight chain in one place. That may have to be changed. could have something to do with it... |
F4i's don't have twitchy throttles, so something is up with your bike
