Side fairing well nuts seized
Hey everyone, on my '04 F4i when attempting to remove the side fairings, I'm seeing the nut inside the rubber casing spin freely in at least two mounting points and I cannot get it unseized. If I am forced to drill through them to remove them, what are the correct size nuts/bolts/rubber seal to replace them?
Thanks for the help! Would love to do some maintenance on this bike if I can get the fairings off.. step one
Too bad cuz I'd buy tons of them if they were.
They are def M5 and IIRC, the well nuts are M5 x 15, with a 10 mm wide hole.
M5 shouldered, allen, button head bolts to fit.
They are a pita when they seize as there is nothing to grab, even if you do have access. Simpler to just drill the heads off the bolts and replace the whole lot.
