Short in Electrical? No fuel pump or headlights.
Just might take you up on that if this other guy falls through. He sent me a message right as I was getting ready to respond here. Appreciate the help, I'm still keeping hopeful I can give it a good smack and get it started like last night, or find an allen wrench to check the BAS and bypass it so I can exclude one more issue.
For sure. I'm already at home so I'm just going to rent a trailer and figure it out this weekend. Thanks for the offers I just didn't want to waste your time if it turned out to be more than a short. Easier if I just bring it home.
where did you check the BAS? at the sensor itself, or the main harness (by the left intake tube)? i had a similar experience after pulling the upper fairing a while back. my situation ended up being the main harness wasn't making a solid connection on the green (BAS ground) wire.
symptoms were everything worked like normal, except no headlights with brights indicated & no fuel pump prime
I'm 99% positive it's a short since when I hit the headlight on Tuesday night, everything popped right back on. Smacking the headlight since doesn't seem to be doing anything this time around though.
Yeah that basically sounds like the problem with mine, as soon as I took the headlight off mine some things moved around and then it worked and then went back to not working.. As soon as I found the issue and jumped that wire to the negative terminal of the battery everything worked fine (I mean, before I burned through another ground somehow by not tightening the fuel lines tight enough leading to spills which of course burned and burned a ground line, but that's beside the point). If you take a voltmeter to the positive ends of the headlights and connect the other end of the voltmeter to ground are you getting 12 Vish?
After fiddling with it and checking connections and whatnot, everything popped right on, so I'm wondering if I just had a loose connection from when my front end was worked on. Running fine today, no problems turning it off and on so I'm not sure, I didn't really have the time to trace every wire. I have some days off coming up next week, so as long as I'm running this week, I'll probably pull the front fairing and try to trace it down and make sure all my grounds are good.
