Shifter adjustment procedure- Rearsets
I put on a set of aftermarket rearsets. Sometimes, I don't get a return when going to 2nd and therefore can't shift to 3rd. I've heard this is common on aftermarket rearsets and can only be solved by proper adjustment. However, I don't see any reason why mine is out of adjustment or binding and causing this issue. What should I look for?
hmm, I dont know about the not returning. I had put Woodcraft rearsets on my F4i, and I did have several missed shifts, up and down, and that was do to my lever being misadjusted. I didnt think it was either, but just to eliminate the problem, I went ahead and adjsuted it and it did fix the problem.
I guess its possible if you are not getting enough "throw" on the shift lever, you may not get the shifter linkage to set and reset correctly. I may be worth a try to make a larger adjustment to shorten or lenthen the rod and see if it does make a difference.
Sean1000f
07-02-2013 01:44 PM
