Setting Forks Flush With Triple Tree
Old 09-25-2018, 02:55 PM
Default Setting Forks Flush With Triple Tree
Hello everyone, I'm trying to mount my protapers with protaper oversized risers but I can't clear the top of the fork tube. if i were to beat it down to be flush with my triple would it just completely throw off the stance or would it even be noticable?
Old 09-25-2018, 03:39 PM
The bike will handle horrible. Raising the front slows down front end response, making the bike steer like a harley. The front end of the bike needs to be lowered from the factory not raised. If you raise the rear end enough to compensate you might be able to make it work though.
Old 09-25-2018, 03:54 PM
I apologize i meant lower it not raise it. Would it just consist of lifting the front end off the ground and beating down on the fork stems? also would it make the stance of my bike ride all goofy?
Old 09-28-2018, 01:46 PM
The more fork tube showing above the triple tree, the lower the front end will be. Setting fork tube tops flush with triple will raise the front end. I had like 30mm of tube above my triple back when I ran the stock rear shock.
Old 10-07-2018, 01:02 AM
I know this thread is old. If you can get away with not makin the forks flush you wouldn't be raising it as much. When I first ran MX bars, I had to raise my bike (aka make the forks lower in the triples) but only about HALF way to being flush for my specific risers/bars. I personally didn't notice any difference in riding, then again, I'm not a pro track rider who is super keen on tiny changes.
Imo the f4i's front end is pretty soft to begin with, so I don't think raising the front slightly would throw your riding off much if any. Unless your a track rider. with a properly setup suspension for your riding/weight (aka sprung/valved for your weight, sag set properly etc) I doubt it will really effect you too much, if you even notice it.
smee44
08-09-2010 03:03 PM
bluej511
09-10-2007 09:58 PM
thunder31634
04-19-2006 12:42 AM
Quick Reply: Setting Forks Flush With Triple Tree
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
