RR forks and f4i forks
Hey yall i just found out my right fork seal is leaking and that my tire wear on the front tire is not even and its wearing more on the side where the fork is leaking. After i bought my bike i found out that it had been wrecked and the forks are tweaked casing bad tire wear and the steering is a bit cocked to the right.
My friend has a 04 600rr and said if the forks and triple tree are the same as my 02 f4i he would give me his spare fork and triple trees. Are these two parts interchangeable with the rr and f4i? thanks |
the fork tube size is larger on the RR I believe, so you would need a complete front end off a rr. far as fitting it on the F4i, bearings may be a diff size but I am not sure. Other than that clearance for the clipons is the only thing that may need tweaking as they mount under the triple tree on the RR.
I'm wanting to possibly do a inverted fork swap on mine one day. or just get a RR lol |
