Routing For Throttle Cables ?
Old Apr 6, 2020 | 02:16 PM
thatonecbr's Avatar
Default Routing For Throttle Cables ?
It has been issue after issue that I am having to fix, due to the previous owner taking things off, hacking things up, etc. Upon doing my spark plugs, I noticed that I only had one throttle cable instead of 2. So I double checked my handlebars, and sure enough there is only one cable running from it. The cable that is currently on the back is in the top position on the handlebar....however, it runs to the lower slot on the bracket near the throttle bodies. Is this correct? The top cable (on the handlebar) runs to the lower slot on the bracket near the throttle bodies, and the lower cable (on the handlebar) runs to the upper slot on the bracket? I just want to make sure everything is correctly set up when I get the new lower cable.
Old Apr 7, 2020 | 02:29 PM
SunBlue's Avatar
Ooh I want to say that's right but honestly I can't remember, maybe someone else can chime in.
Good thing is you'll know if it's wrong by looking at it open the butterfly valves
Grog
Jul 17, 2018 08:58 PM
Wants a CBR
May 18, 2010 08:37 PM
RoosterF3
Oct 25, 2009 08:57 PM
Kuroshio
Sep 12, 2009 11:29 PM
Ntense
Apr 28, 2005 03:31 PM
