Rolling off the throttle..
Hey all so I got my f4 and maybe its just because I was riding a different bike before but this f4i really throws me forward when I let off the throttle without any braking. do you guy think that I should be concerned about the brakes not lining up? like any motorcycle its worse at higher rpms, but even in low 2nd gear and low 3rd gear ( 2-3k rpms) it will really push me forward and my speed quickly drops.. any thoughts?? thanks! <3
sounds as tho it may have lower gearing (less teeth on front sprocket, more on the rear). I'd check that first. Are you rolling off the throttle or just snappinng it shut? It will be jerky or jumpy if so.
granted I am still getting used to the throttle and do roll off quickly I still dont think im snapping it... so should I go count the sproket teeth on the front and rear do you think?
it should have the number of teeth stamped on the sprockets. the stock is 16 for the front and 46 for the rear i think? feel free to correct me anyone.....
and what do you mean by the brakes dont line up?
ORIGINAL: KittenRR
well my first bike is my 600rr, and it is pretty harsh with the on-off throttle, from what i hear it is a little more abrubt than a lot of other bikes, and a lot of people say a power commander really helps with the smoothness at least with the on transition
just checked the gearing and it looks to be stock 46 in the rear but hard to tell on the front, but looks OEM...
what i thought was happening from my experience with normal bicycles is when the rear or front brake is not lined up and drags whenever in motion.. is that possible with a motorcycle? seems like it might be but im not sure.
well, its normal to hear a little bit of brake drag on anything with disc brakes. it should be very slight though, as the pad just kinda rests on the rotor when no pressure is applied. is that what you mean?
