Removing gas from tank
Hey guys... I am currently taking my tank off for it to get painted and i siphoned what i could out of it and when i took off the bolt that goes to the fuel rail i got a little more out.. There is still a little gas left in the tank... Any suggestinos of getting the rest out with out opening it up and turning it upside down and shaking it would be a great.
Thanks
Thanks
I had to do the same thing not too long ago. I did what you did, took the bolt out from the bottom. I couldn't get all the gas out that way either and I had everything unplugged from the bottom. I had to leave it turned upside down for a little and there was still gas in there. When I was sanding I just taped up the gas hole on top and just let what was left of the fuel drain out from the bottom. But this was my 1st time removing the tank myself so other people may have the correct way to drain the fuel. Good luck.
