Removed fairings now wont start help!!!
i pulled the headlight and side fairings lifted the front tire suspended the bike to change oil bike wont start how sensitive is the tip sensor? reset relay? any ideas?
you need the headlights plugged in to start the bike. If theyre not connected the fuel pump wont prime. Just plug em back in to the harness and she should start right up.
fuel pump relay? I checked the fuses they are good
lol man i was worried, plugged them in and started right up thank-you i need a manual for this thing any suggestions on a get source to get one
The bank angle sensor (AKA tip-over sensor) is located on the headlights. If it is removed, the bike won't start.
Manuals can be found online - just search this forum, they've been linked to many many times. |
Also, I'm not sure what you meant by "lifted front tire", but if you're using motorcycle stands, never lift the front tire by itself. Always use with a rear stand.
yeah you can get em here Stephy G's CBR F4i Page haha youre not getting along with this bike are you? Once you figure out all the stupid basic stuff like this you should be set. Hondas are a nightmare electrically compared to other bikes from what ive seen.
Know man def not getting along with it and the problem is someone before me has done some rigging so its a nightmare..just got it back together nothing lines up the back plactics that is because of the swing arm lots of zip ties lol
and know i have an electric hoist and straps mounted to the ceiling atach to side of fram and press a button works pretty well |
