rearsets draggg
rearsets draggg
so whenever i actually get close to dragging a knee my rear set will catch the ground and usually throw a lil wobble on me.... no bad when im exiting the turn, but not that fun at apex
and i pick up my feet and put my toes on top of my pegs already.... and honestly, as much as i was dragging them today, i doubt spending $400 on a pair of rearsets to raise it only an inch will really fix this discomfort.
any ideas? or should i just get a 1kRR?
RE: rearsets draggg
ORIGINAL: JVracer04
RE: rearsets draggg
I had the same problem. I removed the feelers then took some 1/8" aluminum to raise my stock rearsets up 1/2". Now I don't drag my rearsets or my toes. Only cost me $10...
Edit: As abadfish said it probably was my body position and I have been working on that but I like the new position of my rearsets.
RE: rearsets draggg
Yo I got the perfect solution for you! Go to ebay and look for a guy with footpeg risers! I got them and the position on the f4i is so much better! There only 50 bucks guy ships them from canada! Just type in F4i in the search your find them! Easy to install, you wont need the gear shift extender for the bar! Just change the postion at the clamp!
The pegs are moved 1inch up and 1inch back or the oppsite for tall people looking a more comfortable ride!
RE: rearsets draggg
RE: rearsets draggg
i used to think if i didn't drag my pegs it wasn't a good ride. on the street, i used to ride the corners like it was motogp. i was always dragging my pegs and even sometimes my stock exhaust on my r6' until i finally lowsided the bike at 45 mph at deals and i woke up. f4i's don't have as much ground clearance as r6's so mine drag sometimes too. that much lean angle on the track is fine but trust me you'll eventually lowside on the street. i'm trying to hang off the bike more to keep the same corner speed and keep the bike more upright.the f4i definitely needs rearsets and an aftermarket exhaust if your planin on goin to the track. cheers
RE: rearsets draggg
yeh i try to be really careful when i get that low , any change in the road condition could send u down quick.... ive had my close calls but usually a tad more throttle and a push and the handlebars sends it right back up
i actually almost highsided this past sunday cuz i couldnt really tell my front wheel was in the air when i was still exiting a turn, and when i shifted into 3rd it gave me a pretty good kick in the nuts since i wasnt quite on the seat yet.
RE: rearsets draggg
yo jv...check your posts mang...
f4i like racing a minivan? lifting the front exiting apex? dragging pegs before knee?
all signs of rider inadequacies and not the bike's inadequacies.
sure you can get a 1krr...but you still won't be a better rider. just faster in the straights.
