Rear wheel installation question. 06' F4i
So had to remove and re-install the rear wheel, everything is real easy but I forgot where on the axle the big metal washer goes...
Does it go on the outside of the swing arm under the nut on the right side of the bike, or in between the spacer and the brake caliper ?
Here is the diagram from ronayers, and the part i'm talking about is #18
http://fiche.ronayers.com/Index.cfm/...#39;01-'06)
Thank you,
Boris
Thank you,
Boris
