rear sprocket f***d up!!!
i did -1+2 vortex and did 520 chain... a month ago.,and the rear vortex sprocket a bought italuminum black(extra life)...
now my rear sprocket is eaten up, it's like i used it for a couple a years...
i bought the kit from motosport.com(if it helps)
and i also upgraded to a barnett clutch., but no whellies, stopies, or whats so ever.
so my questions are:
1- how long should a vortex rear last??
2-are their any chances that this sprockets are under waranty???
any input will help., thank's guys!!
RE: rear sprocket f***d up!!!
iv heard alot of bad things about vortex about how the aluminum is weak and breaks/chips teeth off and stuff. you might be able to exchange it depending on the company you bought it from but usually it ends with your loss. go with stealth or afam, something with anodized steel it last alot longer
well it was my first change, and i did it my self...so maybe i didn't tight something...but i made shure that the sprocket bolts where tighten enough, and that the chain slack was not more then 1-1,5 inch,and the wheels were alligned...so i don't know, i'l going to post some pics tommorow before changing back the stock sprocket
