rear cowl help
RE: rear cowl help
ORIGINAL: xtremef4i
You just have to work it a little. It is really flexible and you do not have to woory about it breaking.
I've found that if you start with the left side of the fairing and work it over the reg./rect. then work the right side over those relays, then go back and slide the left side under the sub-frame, then same for the right, then push the whole thing up towards the tank, it goes on without too much complaining. I kinda wish Honda had made that a 2-piece fairing, though. Would make things a lot easier.
RE: rear cowl help
ORIGINAL: Bob The Great
