Rear Axle NUT
on a 2006 CBR f4i what ft-lbs should the rear axle be torqued to?
thank you, So Cal Rider |
Moved thread
I moved your post to the F4i section because "forum help and suggestions" is actually only for Forum (the actual system) related issues..:)
69 foot-pounds.
Hey CJ....wat size is the axle nut? My tool box doesn't have anything close to that size rachet
u need 22mm and 27mm size sockets 1/2 inch drive
does the sprocket fall out when u take the axle nut and tube out? u need to take the rear caliper off too? which side did u break loose first? thanks.
The sproket is on a carrier and is held in place on the wheel. You need to remove the axle and the wheel. Caliper removal is optional (sometimes).
For future reference, there is a table with all the important torque values near the front of your service manual. In mine it's call Table 1 I think. Anyway, if you don't have a service manual you'd be wise to get one. Invaluable.
