quicker steering response
RE: quicker steering response
i think he meant raising the forks in the tripple, which would lower the front end
that would give you quicker turn in but at the same time the bike wouldn't be as stable midcorner so its a tradeoff
if its turning in too slow try adjusting your body positioning accordingly. use more steering input and put more weight on the inside peg to make it turn in quicker
ORIGINAL: SquireSCA
Easiest thing to do is swap to better tires. The stock BT010 tires are more like sport-touring tires these days.
I went to Metzler M3's and there was a very noticeable difference in handling. Pilot powers would turn better as well.
+1
I sport the PP's and they make a hell of a difference also if you want to turn quicker make sure as you are approching a turn (decreasing or increasing radius) to pick an appropriate Appex line (where you'll intiate the turn) look thru the turn and position your body to hang properly (no second guessing)the bike will make if initiated correctly and make it a quick steering using only the inside arm to steer. As i said if you HANG properly you won't even have to lean the bike that much (no scrapping parts) which is a good thing if along the turn you'll need to make some adjustment because of a road hazard (think of it as insurrance, always leave some room in case of error or unexpected thing should arise)
ORIGINAL: ninetyfivehp
anybody done this? my F4i steers a lot slower than my R6. i just want to quicken the steering a tad without inducing any headshake. thanks
Neu16
05-25-2013 01:18 AM
