Quick Sprocket Question
This would be true for highway cruising in 6th gear. Anything else you can pop it into the next gear and your gas mileage will not decrease and may even improve. I usually dont go higher than 3rd or 4th gear for everyday riding in residential areas. So the type of riding you mostly do is also a factor. Plus if he goes with the 520 chain and aluminum sprocket the weight and mass reduction will also help his gas mileage.
My renthal rear sprockets would last around 14,000 miles if I remember correctly. Yes more torque applied to the rear wheel [gearing change] will make wheelies easier.
Wow Nickp is way off base here. The 520 conversion is NOT any "faster" than a 525 set-up. Ok you might save a tenth or two on your track time (so I guess it is a little (very little) faster), but for what it's worth, you'll be better off getting a 525 kit in the gear ratio you desire (16/46, 15/48 or whatever, mine is 16/50 and 15/50 when I wanna get spirited). The 525 chain is alot stronger than its 520 equivalent (check any mfg.s website and compare their 525 chain to their otherwise identical 520 chain noting their tensile strength). Like previously stated, how often do you ride at 140 mph? More often than stop n go street riding? Proly not. You need to weigh the pros n cons of all the changes and decide what is best for you. If all you do is street riding, mostly under 60mph, then you'll be happy with the 15/48 gearing, if you do alot of freeway riding, you might wanna stick with stock gearing or even get a smaller rear sprocket. If you rarely do track days, then stick with the 525 setup and find some steel sprockets, the weight reduction (to me) is not worth giving up the longevity. For nickp it obviously is worth the sacrifice. So while he'll be replacing chain n sprockets soon, I'll be riding the same kit for years to come.
Nick, I don't think you're way off base at all if it helps any. lol...
I'm not a big fan of the aluminum/520 setups either, btw. It's just not worth it for a street bike or an occasional track day ride. Steel will last longer.
Or I guess you could get one of those super cool space sprockets that have aluminum carriers and steel teeth, but those biches are real expensive.
Well thank you kilgore. Yeah Id probably buy one of those once just to do it then id be over it by the time it wore out and id go back to all steel. Those titanium ones intrigue me though. $180 but a "lifetime warranty", if you ever wear it out theyll send you a new one for free. Sounds like a good deal, never having to worry about changing a sprocket again, but it also just sounds like a gimmick, not sure how i feel on that one.
Thank you guys for all the great info and I appreciate it. I was actually just going to ask which would be better between 520 or 525 lol so thanks for answering that for me too. Yeah I ride my bike alot and mainly just street riding so I think im guna stick with steel sprockets and 525 chain with +2 in the rear bc I dont wana replace them every season. Thanks for the sprocket offer Tori but I want to stay 525. Who makes some good sprockets that last? and would a D.I.D chain be a good choice? Thanks again!
EDIT: Wow, nvm about aluminum. Al flexes way more than Steel and more than Ti also. Ti should last much longer though than either.
ROOKIE 09
03-25-2011 07:26 PM
