Quick Question?
Quick Question?
A buddy of mine has a cbr600f4i that needs the rear tire replaced. Somehow he was given a rear tire (Dunlop) but it is a different size (190/50/17). I have replaced the rear tire on my bike so I offered to help him out. I was thinking this tire might be too big to mount on his rim but I wanted to check with you guys first. I have a busa and this is the same tire that I have on the back of my bike and it just seems like it would be too big for him to have on his bike. By the way, his bike is completely stock, including the rims. I appreciated any advice you guys can give me. Thanks!!!
Chad
Chad
RE: Quick Question?
i would stick with a 180 rear, because i read in a magazine that upgrading to a larger rear on a sport bike significantly decreases cornering abilities. The reason this is because stock the bike is set up with a certain weight balance. Such as when making a turn the bikes center of gravitiy is in the right position so that the bike has the ability to lean all the way over. now when upgrading to a 190 it may not sound like much but you have to take in account that the tire is wider and i also believe taller. The rim size is the same but the crown on the tire i believe is different. You may not notice a difference, but from what ive read upgrading is not a smart move if your riding it other than the drag strip. And plus these bike have gone through years of engineering and stock the bike is balanced, so by changing to a bigger rear tire, the bike balance could be affected.
viva_brasil
06-09-2008 04:38 AM
