quick qeird question
i just noticed on my recipt for my exhaust order i picked the Cali model exhaust. I know those guys got smog restrrictions out the wazoo so should i correct the order? Or is it just a stamp?
RE: quick qeird question
i think it just means you have a place to plug in a o2 sensor it looks like you got a 06 so your bike is built to ca emmisions standards anyway i believe atleast thats what i was told which once again just what i was told means not only that you have an o2 sensor but a less aggresive cam i could be wrong here tho
It means your new mid-pipe will have a bung for an O2 sensor. You could send it back, or possibly correct the order before it ships. If not, then get a bolt to plug the bung with. Do a search for "O2 sensor" and there is a thread that tells exactly what size bolt to get. I would use high temp sealant on the bolt threads. Your new mid-pipe might ship with a bolt in the bung.
This is the only difference between a CA model and a NON-CA model. |
You'll need the CA model exhaust since yours has an 02 sensor. Let the order as it is.
When I ordered my Yosh pipe, I ran in to a similar thing. All 06 F4is have an O2 sensor (as far as I know). The exhaust I ordered was a non CA model. If that is the case, all you need to do is order an 02 sensor eliminator. Dynojet has them for around $20.00.
If you end up with an exhaust with an O2 hole and you don't run a sensor stock, just plug it. |
sweet thanks fellas
Man, a bolt in your bung? Depending on the size of the bolt, that might hurt a little bit...[sm=alcoholic.gif][sm=badidea.gif]
ORIGINAL: lifties It means your new mid-pipe will have a bung for an O2 sensor. You could send it back, or possibly correct the order before it ships. If not, then get a bolt to plug the bung with. Do a search for "O2 sensor" and there is a thread that tells exactly what size bolt to get. I would use high temp sealant on the bolt threads. Your new mid-pipe might ship with a bolt in the bung. This is the only difference between a CA model and a NON-CA model. |
| All times are GMT -5. The time now is 08:23 AM. |
