-   F4i - Main Forum (https://cbrforum.com/forum/f4i-main-forum-11/)
-   -   question about Hotbodies undertail/running lights (https://cbrforum.com/forum/f4i-main-forum-11/question-about-hotbodies-undertail-running-lights-124570/)
grizzle Apr 27, 2011 11:33 AM
Hi,
Will I lose the running lights on my '02 F4i if I install the dual round LED undertail kit from Hotbodies? I've done some research and some results indicated I will and others seem to say that no I won't....any help please? Don't really like the idea of riding around with only brake lights and indicators at night (no running lights).
Thanks!
F34Me? Apr 27, 2011 12:02 PM
You can install diodes so that the indicators are ALWAYS lit and flash OFF instead of on. You put a diode on each of the hot wires and then tie them together to the hot wire of the indicator. The ground is connected as per usual. If I am speaking greek I suggest you get someone at Radio Shack or similar place to explain it to you.
grizzle Apr 27, 2011 12:30 PM
great thanks, any particular specs on the diodes?
01hondaf4i Apr 27, 2011 12:32 PM
No I just installed mine. You do NOT loose your running lights.
grizzle Apr 27, 2011 12:40 PM
awesome, thanks for the replies fellas! Any tips on installing it?......How hard was the lock mechanism to get hooked back up properly?
__Z__ Apr 27, 2011 03:06 PM
they suck and arent bright, send me ur undertail and $70 bucks and ill take car of it lol
http://a1.sphotos.ak.fbcdn.net/hphot..._2077873_n.jpg
01hondaf4i Apr 28, 2011 08:01 PM
Yes they are not super bright. I didnt hook my rear seat cable up. I got lazy. Use a dremel to cut the plastic. It makes the job soooo easy.
