Question about 600RR to F4i swingarm swap
I searched this and couldn't find anything so I was hoping someone could chime in if they had any info...
I recently picked up a complete set up from a 600RR and want to do the swap to my F4i. The question is, instead of making the spacers for the caliper bracket can you just use the 600RR rear wheel? I couldn't come up with a reason as to why this couldn't be done, but I haven't started the project yet and wanted to get info/opinions first.
Thanks,
Brian
Thanks,
Brian
And I believe the 04-05 are the years that will work. After that the upper shock mount is cast into the swingarm. And you'll need to grind it some n flip it around.
and any 600rr arm will work but after a certain year you have to fabricate some spacers....
get in touch with vangil if u want more specifics on that...
umm you running the 1k shock with the res facing forward? I was told you wouldnt be able to with the new swingarms, thus needing a 04-05.
Oh yea and proper spool mounts, better rear shock w/ more adjustability
