Proton Flush mounts: Question!
I'm buying proton flushmounts to replace my front signals and keeping my stock rear signals. Will the blink rate on the rear be faster than normal?? Need some info guys.
RE: Proton Flush mounts: Question!
If the protons are led, I doubt it.
They do make a turn signal flasher for the F4i that makes led blinkers blink at the proper rate. |
Why dosent anyone like the high blink rate? I think its BADASSSSSSSSSSSSSSSSSSSSSSSSS!!
ORIGINAL: 02cbrf4i4u Why dosent anyone like the high blink rate? I think its BADASSSSSSSSSSSSSSSSSSSSSSSSS!! |
ORIGINAL: 02cbrf4i4u Why dosent anyone like the high blink rate? I think its BADASSSSSSSSSSSSSSSSSSSSSSSSS!! And the rears will flash at the same speed as the front. So if the protons are led's and you don't get resistors or anything to slow the flashing down, the rears (even though they're still stock) will flash faster. |
Actually the Protons, even though they are LED's, are internally balanced so it doesn't change the blink rate, so it'll still blink at the same rate as it does stock.
Protons are cool though... you can program 3 different flash patterns. I'd like to get them for mine but don't see them for the F4i, only RR's |
I have the protons on mine and I love them. I also have LED rear pegs, so in combination with those it does have the faster flash rate. I do like it though and don't have any plans to slow them back down.
I've got the protons. I wouldn't recommend them.
FWIW, the internal resistors on mine don't work. They still flash fast for me, and they are the only LED's on the bike. |
