-   F4i - Main Forum (https://cbrforum.com/forum/f4i-main-forum-11/)
-   -   Pre-Installed Hotbodies Undertail, Having Brake Light/Rear Blinker Issues, Need Help (https://cbrforum.com/forum/f4i-main-forum-11/pre-installed-hotbodies-undertail-having-brake-light-rear-blinker-issues-need-help-89314/)
josh99ta Mar 16, 2009 12:11 PM
When I bought my bike it already had a Hotbodies undertail kit with integrated rear blinkers. They worked fine for the first 200 miles or so after I bought the bike. I installed front Hotbodies flush LED turn signals this Saturday, tested everything, and it was all a-okay...front and rears worked fine.
The very next day I undercover the bike and go to ride, but all wasn't well anymore. Front turn signals flashed as they were supposed to, but the rear brake light and turn signals do not work anymore. When I put on a left or right turn signal, both turn signal indicators on the dash flash really fast. When either the front or rear brake is applied, both turn signal indicators on the dash light up solid and stay solid until I release a brake.
Are these indicator functions a way to tell me one of the rear brake lights/turn signal bulbs is out (both lights come on, just the high filament brake light/turn signal on either side in the rear doesn't work at all)? Or does this sound more like a wiring issue?
Also, when I did the Hotbodies front LED signals, I used both green ground wires to the black Hotbodies wires, and I used only the solid orange (left) and blue (right) wires to the red Hotbodies wires. The striped wires I didn't use at all. Is this correct (the Hotbodies instructions weren't very clear here)?
Thanks a ton for any help guys. Trying to work out all the bugs I can on this bike so I can ride safe and trouble-free as soon as possible.
Stephens Mar 16, 2009 08:28 PM
Thas the correct wiring, its possible your connections might have come loose. I had a wiring come out of the connector. I reconnected it and its all good. So, check all your connections of our wires.
josh99ta Mar 16, 2009 10:58 PM
The front turn signals I installed myself I soldered the connections on and heat shrunk tubed the bare wires, then electrical tape was used to seal that. I don't think any of my connections on the front LED turn signals came loose. Plus the front turns work perfectly.
It's the rear brake light/turn signals that are the problem. Neither the brake light nor either turn signal work, and when I try to signal a turn both indicators on the dash flash rapidly. When I apply either brake both indicators on the dash light up and remain lit as long as I have a brake engaged. Is that a blown bulb warning signal (like some cars have the same thing, if a bulb is out even one filament on a dual filament bulb you'll get a solid signal indication on the dash to let you know a bulb is out)? Or is it a wiring issue in the rear integrated blinker undertail kit?
skoobydoobie Mar 16, 2009 11:42 PM
Check the connections on the rear. Like Steph said it probably came loose.
josh99ta Mar 17, 2009 11:14 AM
I'll be doing that today. The connections in the rear aren't soldered so I'll probably just redo all those and solder them. I don't trust those cheap plastic connectors.
josh99ta Mar 17, 2009 07:15 PM
All connections are soldered and I still have the same problem. I'm pulling all of this from memory, but here is how the Hotbodies integrated kit is hooked up...
Yellow wire to left rear green/striped wire on connector to tail light bulb (dual filament)
Green wire to right rear green/striped wire on connector to tail light bulb (dual filament)
Brown wires out of Hotbodies kit not hooked up to anything (actually completely cut off by previous owner)
There is also a green wire behind the VCM (?) under the driver's seat that is connected to a red wire that I believe feeds to the Hotbodies integrated tail module or back by the rear lights. I didn't pay as much attention to this, I just took off the butt connector and soldered the connection.
Same problem still. On the dual filament bulbs, neither second/bigger filament is lighting at all (brake lights). The smaller primary filament that is constantly lit is lit at all times, but when the blinker is applied it doesn't blink at all. I'm going to try two new bulbs tomorrow, but does this sound like what it is (and isn't it a coincidence that both bulbs went out at the exact same time) or is it potentially something else (a faulty/failing Hotbodies integrated blinker box possibly)?
All fuses under the seat checked and the blinker fuse replaced and all in perfect condition.
josh99ta Mar 18, 2009 05:56 PM
All connections are soldered and solid, bulbs replaced, and still having the same problem. Any help here guys?
Could the Hotbodies integrated blinker box be crapping out on me?
lester2 Mar 19, 2009 09:25 AM
sound like you need a resister for the turn signal lights. my bike did the same thing, and also soldered all the wiring connections. If you have resisters, check the connection.
josh99ta Mar 19, 2009 12:20 PM
lester, I'm not seeing any resistors anywhere. What kind of resistors do I need? Would it also cause the rear brake lights not to work? It honestly sounds like that is a viable solution...but it's puzzling because everything worked fine before. Maybe the addition of the LED front turn signals produced enough of a difference in the electrical system that the rears now need resistors (or maybe the fronts need resistors too). What did you end up going with to fix it?
Liquidpjear Mar 19, 2009 04:24 PM
Let me know if you find the problem. My lights went from perfectly fine to my front signals just turn off when the signals are turned on. I have the hotbodies untertail and I have reworked all connections and triple checked everything and cant track down the problem.
