PowerCommander use advice
Bought a PowerCommander III
Older serial version but an absolute fleaBay bargain at £2.20 :icon_biggrin: Fitted it no problem, led lights go through knight rider style boot sequence at power on, then sits at the bottom and goes up and down with revs. I used a USB to serial converter, downloaded the software, and installed their map for stock exhaust. Only thing I'm unsure about is the buttons, low-mid-high. How do you know if these are working properly? When I press each one, there's no direct feedback, thought there'd be a light flash or something. Any advice much appreciated. |
that's retardedly cheap. Hook me up if you ever see another. All the ones I've seen were real expensive.
