post ur under tail/ plate mounts
Old 08-16-2008, 04:27 PM
Default RE: post ur under tail/ plate mounts
ORIGINAL: axsys
ORIGINAL: 808HondaLife
axsys- how was the intsallation of your undertail? Was it easy/hard? Did everything line up correctly? How was the workmanship of the undertail? Did it feel sturdy and quality built? I like the undertail that uses the stock taillight and yours looks nicer than the pimpbikes. Also, does it come with those license plate mounting brackets and a light? Thanks.
read through my posts in this thread to answer most of your questions. for the license plate brackets, i just used 2 little L shaped pieces from ace hardware. for the light, i just drilled a hole and glued a white LED sticking through. i like it
oh ok. thanks.
  #42
Old 08-16-2008, 05:27 PM
hero's Avatar
why does everyone hate the two circle lights so much?
  #43
Old 08-16-2008, 06:13 PM
dave ls1's Avatar
ORIGINAL: hero
Not bright enough. Function > looks when life is at stake.
  #44
Old 08-16-2008, 06:16 PM
PlayfulGod's Avatar
ORIGINAL: dave ls1
ORIGINAL: hero
Thats sums it up. My taillight has circle LEDs inside it but is much brighter than any of the 2 LED light tails I seen. If they had better LEDS in em, story might be diff. The under I wanted has a custom tailight in it you dont see that often.
  #45
Old 08-16-2008, 06:50 PM
Here is my undertail. Made my own to fit 954rr integratedlight.
  #46
Old 08-16-2008, 06:55 PM
PlayfulGod's Avatar
ORIGINAL: nickj03b
Now I would like so details on that job plz kind sir
  #47
Old 08-17-2008, 10:27 AM
DBEAU's Avatar
ORIGINAL: PlayfulGod
ORIGINAL: nickj03b
+1
  #48
Old 08-17-2008, 12:17 PM
hero's Avatar
ORIGINAL: dave ls1
ORIGINAL: hero
hmm...i was just about to order a hotbodies one. wonder if i should go through with it now. Any way to get them brighter? Has anyone done it?
  #49
Old 08-17-2008, 12:22 PM
PlayfulGod's Avatar
ORIGINAL: hero
ORIGINAL: dave ls1
ORIGINAL: hero
you can order better n brighter LEDs to replace the ones in the tail. I've not done it, but I did do the LED pegs.
  #50
Old 08-18-2008, 10:28 AM
hero's Avatar
Where can I order them and what should I order?
I’m very mechanical, but clueless on electrical and all that. Is this a direct swap or would you have to re-wire some things?
Quick Reply: post ur under tail/ plate mounts
