PLZ. help with cluncking noise at low spd
Old 05-27-2007, 04:12 PM
infamous01's Avatar
Default PLZ. help with cluncking noise at low spd
wat sup guys i got a clunckin type noise at low speed.1st or 2nd gear less the 15 or so. then goes away at higher spd. i'm thinkin and hopin its the chain/sprocket. hopin it not the trans. anyone ever have this prob? i got about 15k on my bike 04 f4i.
oh and listen to this sh*t. i replaced my cct for that rattle. and think the damn noise is back,bout to set my bike on fire, this cct sucks
Old 05-27-2007, 04:19 PM
infamous01's Avatar
Default RE: PLZ. help with cluncking noise at low spd
Sorry about the double post someone can easre one of them,lol my bad.
Old 05-27-2007, 05:02 PM
Hows your chain tension?
HAVOC's Avatar
when you snap the throttle going into wot is that when you hear that "clunking" noise. my 900rr did that and when i looked down i had broken almost all of the teeth on my rear sprocket.
Old 05-28-2007, 04:46 PM
infamous01's Avatar
tension feels ok,it may be a lil loose but not too bad. and im pretty sure all my teeth are there, they might be a lil mis-shaped but not too sure they dont look horrible. i;ll try to tighten up the chain,and iff that dont work...umm.....ill do something else like bring it to the dealer,still under warrenty till 09,yea!
Old 09-11-2008, 04:12 PM
Chunga's Avatar
I had the same problem and I just used brake clean and a scrub brush .clean it real good and apply chain wax and it's gone,
There maybe a different cleaner but my chain had 11000 miles on it so i need something strong It took care of alot of noise clanking and vibration almost like a new bike
Old 09-11-2008, 04:31 PM
moldousa's Avatar
+1 with chunga...
i had the same symptoms,just cleaned and lubed the chain...
Old 09-12-2008, 07:35 AM
yup mine came from the chain. It was the stock chain and didn't even have that many miles on it. there were loose and tight spots that were on the total opposite sides of the spectrum. More than likely u just need to get it adjusted.
blacken77
10-12-2011 05:54 AM
Lashin
03-02-2011 11:16 PM
wvcbrf4i
12-29-2008 11:07 AM
vdubsales
08-03-2006 03:49 PM
Quick Reply: PLZ. help with cluncking noise at low spd
