Please help Bike Week is only 5 days away!
all this **** about fuel lines and whatnot, girl your bike isnt starting for something stupid, like a clutch sensor, starter relay, fuse, kickstand sensor, hell your clutch might be adjusted to low so when u pull the clutch in the start it its not working, its something little and stupid, find someone that stunts, theyll fix it in a heartbeat
[&o]Ok so I admit I am a girl and I don't know alot about fixing the bike [&o]But I can RIDE THE DAMN THING
So i was wrong ....when I turn the key the fuel pump isnt turning on . So I took the tank back off drained it and was going to ck the wiring . I was using a wire tester and when I touched the main wire that plugs into the bottom of the tank it sparked. Guess what ? Then the fuel pump starts working
BUT then I turned the bike off and [&o]the fuel pump didnt come on again ! Is there a ground wire or something somewhere for the tank that maybe I forgot to connect when I tore the bike down to polish th frame ?
![Big Grin](https://cbrforum.com/forum/images/smilies/biggrin.gif)
