Passanger pegs with blinkers
It's pretty easy, and very noticeable.
I used Yellow 3mm prewired LEDs from Oznium: http://www.oznium.com/prewired-leds
If they are not pre-wired, you will need LEDs, resistors, and wires. I wouldnt use a board, to hard to hide in the peg. In case youve never done it before, resistor value can be determined using R = (Vs- Vd)/Id
R = Resistor Value
Vs = Supply voltage (12V)
Vd = Diode Voltage (found on your led spec)
Id = Diode Current (found on your led spec)
LEDs are directional(wont work if wired backwards) and I typically wire them in parallel with a resistor for each led. I can go into more detail on the wiring and such if you want, im just not sure of your experience level with LEDs.
R = Resistor Value
R = Resistor Value
R = Resistor Value
You shouldn't need a board to mount them on. Looks like if you're using 5 or 6, wiring them in series should replace the need for a resistor. I've considered starting to make these. I have a small powder coating shop so I think a black pair of these would look sweet. If any of you guys would like to be my experiment, I'll pc your pegs and install led's for materials and shipping cost only.
Where are you located? I may have some powder coat work for you.
I'm in MN. 40 minutes south of Minneapoplis. Great, I'd love some more pc'ing work!
Here's the deal with wiring LED's
Series-
Positives-
-Don't have to use resistors. (if you calculate correctly)
-Smaller install
Negatives-
-One LED open ciruit will kill them all (open circuits don't happen all that often)
-Need to be a little more savy at wiring and insulating.
-Limited number of LED's
Parrallel-
Positives-
-Unlimited number of LED's (only limited by the total power of your system)
-Basic wiring
-One LED open circuit will not affect the rest (still a bummer to have one out though)
Negatives-
-Need resistors if using 12v power. (resistors for numerous LED's are large due to the fact they need to be higher wattage to accomadate)
-Bulkier install
It all depends on the application.
Series-
Positives-
-Smaller install
Negatives-
Parrallel-
Positives-
-Basic wiring
Negatives-
-Bulkier install
For multiple LED's
-smaller watt, higher ohm resistor on each LED
-single, higher watt, lower ohm resistor for all
I believe the write up mentioned was mine. I did this in an afternoon w/ no real planning aside from buying leds. I HIGHLY recommend using oznium.com product. They sell prewired, waterproof, with resistors all in their own silicone caseing already. Using their product I was also able to get brake lights in the pegs. 3 brake, 3 blink.
Drill 6 1/4 inch holes, 3/8 on center. Worked like magic, a little squeezing to fit the silicone in and they snapped right into place perfectly. Sealed the whole back of the peg with clear shower sealing silicone and they worked perfectly for 3 years.
However, with a passenger on the bike they can't be seen.
