Parts source in Europe
I was searching for a set of injector O-rings (16010MCJ003) but cannot find any worldwide! Honda doesn't sell them anymore.
Does anyone know the specs of these rings, so I can get them anywhere else in Europe?
Partzilla is showing 16472-MCF-003 for the 2005 CBR600F4i and has then in stock :-
https://www.partzilla.com/catalog/ho.../throttle-body
Odd, it shows it as in stock from here unless I'm looking at totally the wrong part, the o ring on the injector, part no 10 on the page I linked to?
No, it's number 2. A set of 4 O-rings at the front and 4 at the back of each injector.
Number 10 are rings for the starter valves, which happen to be unavailable at Partzilla.
I apologise for the typo, I meant part number 16. - I hadn’t realised you needed part 17 as well.
Says available to order here:
https://twowheelsparts.com/gasket-set-16010-mcj-003
you might be lucky
You could also try an o-ring supplier with the dimensions that you need:
https://www.polymax.co.uk/o-rings/
you might be lucky
Revnge_SevnFold
Aug 11, 2013 11:03 AM
