Oxygen Sensor Harness plug options
5 Attachment(s)
Okay so I started a project and the short version of my question is this: Where can I buy the male and female wire harness plugs for the Oxygen (o2) sensor for a F4i?
The long version is as follows: I have a california model 954rr, not an f4i, but the o2 sensor plug is the same on both bikes(the sensor is not the same but that does not matter in this situation.) I used a 330 ohm resistor to eliminate the o2 sensor without getting the annoying FI light. The performance increase was incredible and the low rpm cruise was smoothed out dramatically. However, the fuel mileage took a big hit. Prior to this mod I was getting 140 to 150 miles before the fuel light would come on. After eliminating the o2 sensor, I could only get 120 to 125 miles before the fuel light would come on. It occured to me that I can put the o2 eliminator circuit on a switch with a DPDT relay. Then I could have the best of both worlds with an "Economy Mode Switch". I have gathered all the wire, the relay and the tiny switch that will go inside the left clipon control housing. I would like it to be, basically, plug and play. This is where the problem is, rather than hack up my wire harness, I would like to have male and female plugs, that plug the unit in, between the o2 sensor and the bike's wire harness. I, initially, thought that Honda cars would have the same o2 plugs as the bikes and that a quick trip to the pic a part would have it sorted. After a lot of google searching and comparing images, I decided to come ask you nice folks for some help. If you know of a model of car that uses the same plugs or if you know where I can source a pair of new ones or have any suggestions at all, please let me know. Thanks.:icon_couch: Oxygen Sensor side: Attachment 34089 Wire Harness side: Attachment 34090 Oxygen sensor side: Attachment 34091 Oxygen sensor side: Attachment 34092 Attachment 34093 |
I found that Geo metro from 1996 to 2000 and some Suzuki cars, like the Vitara and swift, have the same plug on their o2 sensors.
I will check the pic a part yard tomorow and see if I can get a set. Wish me luck guys. |
Hye dude.
Your bike comes with o2 sensor? so that did you bike have a HISS? |
Factory O2 sensors are ignored by the bike's ECU under heavy load (ie: heavy acceleration, where most people want to see a performance increase). The O2 sensor is only used to adjust fuel for idle/cruising conditions.
If you are truly seeing a performance increase, it's from something other than the O2 sensor being eliminated. You're idle has smoothed out, and you're using so much gas now because you're running too " rich ". You'll also find that you foul spark plugs more frequently due to this. Unless there's some other reason for you to eliminate the O2 sensor, you'll probably find the bike runs much better (and cheaper ) with it in place/connected at all times. |
Originally Posted by Skinnaird
(Post 1223402)
If you are truly seeing a performance increase, it's from something other than the O2 sensor being eliminated. You're idle has smoothed out, and you're using so much gas now because you're running too " rich ". You'll also find that you foul spark plugs more frequently due to this. Unless there's some other reason for you to eliminate the O2 sensor, you'll probably find the bike runs much better (and cheaper ) with it in place/connected at all times. None of your reply helps with the original question. I am not here to debate whether or not this mod works on my 954rr. Please don't troll in my thread by acting like you know something that you clearly do not. |
3 Attachment(s)
I went to the Pic A Part and got a couple of sets (o2 sensor harness plugs), from a Suzuki Vitara. They are exacly the same, except the female end is green. They have different colors on the four wires and the o2 sensor end is a only about 5 inches long. I soldered longer wires and built the device already. I will test it out for a few days before I drill the left clip on control for the switch.
Attachment 34069 Attachment 34070 Attachment 34071 |
(shrug ). Was just trying to save you the trouble of adding an unnecessary switch. Everything I stated above was not "read somewhere else ". I learned it while writing new subroutines in a eprom ecu to have an engine run in a "lean burn" mode under specific throttle position, airflow, and rpm parameters.
It was my belief that if the mod you wanted to do was unnecessary, the connector you were after would no longer be required, and was relative to your original question. At the end of the day, I'm not concerned with what you do with my advice, or to your bike. In any case, good luck with the project. |
(Post 1223522)
It was my belief that if the mod you wanted to do was unnecessary, the connector you were after would no longer be required, and was relative to your original question. At the end of the day, I'm not concerned with what you do with my advice, or to your bike. In any case, good luck with the project. In any case I am done with this project's fabrication and I am now testing it. It works as expected thus far. I believe that I can help you with your project, far more than you have helped with mine: Your "lean burn" mode could be based off accelerometer input (at least in part), that could eliminate issues you would have of the herky jerky feel of fuel trim in lower gears i.e. (1st, 2nd). |
so you got the O2 sensor plugs, but where did you find the O2 sensor?. im looking for one..that isnt so expensive.
EDIT: nvm i found one on ebay for 17 dollars which is for the f4i itself. all i need now is an O2 bung and some welding |
hey lasvegasharley can you give me some updates how does your bike feel with the O2 sensor on or off?
