oil light and high temp
Bike runs fine then after about 5 mins idle the temp gets up to 230 and oil light comes on starts to blink and bike will shut off and Ideas.. fans do come on but go off right away
Bump
First:
DO NOT RIDE Hope that's clear enough. Whatever is wrong, it's serious if its:
What's the bike's maintenance history? When did you last change the oil and what kind did you use? Coolant level / flush? The temp issue is secondary imo. Bike can run hotter without causing damage. The oil light is major though. If it starts to flash and then the bike shuts down (not coming on after the bike shuts down), you have a problem in the oil system. If you've never changed the oil yourself, change it now. And post more info on your bike. |
Went back in your post history. This the same bike you were reviving from a down back in Feb?
Yeah i just did my clutch and everything im thinking my oil strainer is full with gunk i just put new oil in there honda oem... coolant flush was done back in april/may i realize bike is fine let it run then temp hits 230 bike starts going haywire
Temp related and oil indicator? I don't know the oil system well enough to advise other than don't try riding it. Maybe the oil cooler? Dunno
i gotta video coming up the fan kicks on at 232 and kicks off at 229 bike pops alot like blue flame out of exhaust also...
F4i dead maybe - YouTube here ya go
My Problem: After riding the bike for more than 20 minutes or so and the running temperature is warm (around 230 degrees, or so), the oil light will illuminate/flash when I come to a stop and idle. ONLY when the bike is idling/not moving, and ONLY when the temperature is up there. As soon as I continue to ride and the rev's go back up, the light goes back off. The idle is hardly effected, if at all by the light being on. Bike shuts off when stationary, oil light comes on only when the running temperature is near 230ish. When moving, oil light goes back off. Oil level is fine- spark plugs changed very recently. What's the issue.
I have the same problem. How did you solve yours CBR600RR 2009
Originally Posted by alexf4i227
(Post 1089525)
my problem: After riding the bike for more than 20 minutes or so and the running temperature is warm (around 230 degrees, or so), the oil light will illuminate/flash when i come to a stop and idle. Only when the bike is idling/not moving, and only when the temperature is up there. As soon as i continue to ride and the rev's go back up, the light goes back off. The idle is hardly effected, if at all by the light being on. Bike shuts off when stationary, oil light comes on only when the running temperature is near 230ish. When moving, oil light goes back off. Oil level is fine- spark plugs changed very recently. What's the issue.
