Oil leak from where water pump goes into crankcase
I was riding the other day and I saw some smoke. when i looked, oil was burning on the exhaust, under the oil pan. I stripped the bike this weekend to look for any leaks. I found that there is some oil around the back of the water pump. I know that there is a oil hose coming from the filter to the water pump. Is there a seal that the water pump has? If so it is probably busted and letting oil through. Some picture are below. If any one can help me out it will be appreciated. Thanks
Actually, that hose that is coming from the oil filter is for the oil cooler. I thought the same thing until I was browsing the service manual and saw the oil cooler and traced the hoses going to and from the cooler to the water pump. The only seal that could be leaking oil is the seal in your third, fourth, and fifth pictures. I wouldn't worry about the fact that the seal looks wet though as mine does the same thing, but no oil actually runs out of it. One place to look that is notorious for leaking oil is the cam chain tensioner. My bike would leak oil from the CCT, pool up, and then run down the left side of the bike when I put it on the kickstand. It drove me crazy to the point where I almost pulled my tank off to look at the head gasket because I couldn't find where the oil was coming from!
I had the exact same problem recently. It turns out I had overfilled the oil. The crankcase has a hose that vents the extra oil into the airbox, and from there it drips down all over everything and makes a big mess. I'd definitely check that out first before looking elsewhere for leaks.
